Phyllotaxis AnalysisLink
A Combinatorial Model of Phyllotaxis Perturbations in Arabidopsis thaliana.
DescriptionLink
This package provides tools for analyzing phyllotaxis patterns in plants, particularly focusing on perturbations in Arabidopsis thaliana. It implements algorithms for detecting and characterizing divergence angles and permutations in phyllotactic patterns.
InstallationLink
You can install the package using pip:
pip install phyllotaxis_analysis
Or directly from the source code:
git clone https://gitlab.inria.fr/mosaic/phyllotaxis_analysis.git
cd phyllotaxis_analysis
pip install .
DependenciesLink
To run the algorithms you will need:
- Python >= 3.7
- NumPy
- SciPy
For the GUI:
- PyQt5
- Matplotlib
UsageLink
Basic usage example:
from phyllotaxis_analysis.analysis_functions import theoretical_divergence_angles, is_n_admissible
# Calculate theoretical divergence angles
permutationBlockMaxSize, canonicalAngle = 3, 137.5
angles, coefficients = theoretical_divergence_angles(permutationBlockMaxSize, canonicalAngle)
# Check if a sequence is n-admissible
seqTA = [137.5, 137.5, 275, 222.5, 275, 137.5]
result = is_n_admissible(seqTA, 137.5)
For more detailed examples, see the documentation.
LicenseLink
This project is licensed under the CeCILL-C License - see the LICENSE.txt file for details.
ReferencesLink
Refahi, Y., Farcot, E., Guédon, Y., Besnard, F., Vernoux, T., Godin, C. (2011). A Combinatorial Model of Phyllotaxis Perturbations in Arabidopsis thaliana. In: Giancarlo, R., Manzini, G. (eds) Combinatorial Pattern Matching. CPM 2011. Lecture Notes in Computer Science, vol. 6661. Springer, Berlin, Heidelberg. 10.1007/978-3-642-21458-5_28
Guédon, Y., Refahi, Y., Besnard, F., Farcot, E., Godin, C., Vernoux, T. (2013). Pattern identification and characterization reveal permutations of organs as a key genetically controlled property of post-meristematic phyllotaxis. Journal of Theoretical Biology, 338, 94-110. 10.1016/j.jtbi.2013.07.026
